Components and materials: specifications for a proper integration into systems
Research Front 5
Participants: LMGP (Leader Daniel Bellet), G2ELAB, CEA LITEN, INEEL, IMEP-LAHC, LEPMI, SIMAP
The main three themes developed in the framework of RF5 of Eco-SESA project will be devoted to:
Broad and strong skills exist in the scientific community of Grenoble in these fields. Strong couplings between academic and industrial partners spanning a wide range of TRLs and many synergies through Eco-SESA project should foster cross-fertilizations.
In particular, the integration of the energy needs compatible with eco-district design requirements will be done in strong collaboration with the other research fronts to address the whole line from the development of new materials and technology to their overall impact assessed in respects to urban context and practical uses for inhabitants and stakeholders.
Thin film solar cells: For both indoor and outdoor photovoltaics, the main research aims at working on efficient & low cost solar cells with abundant and eco-friendly materials and processes.
Prototype of an efficient white LED: The key points concern cost, life-time, visual comfort, efficiency, and recyclability using new materials & technologies.
Hydrogen storage: One of the main idea is to develop a reliable and energy-efficient hydrogen purifier/compressor operating at low temperature, compatible for an eco-district.
The production of energy will be focused on solar cells technology by coupling both experimental and modelling approaches. The focus on the efficient usage of energy will concern solid-state lighting by developing original, low cost and efficient LED devices. The storage will rely on the power-to-gas (hydrogen) and on the possibility to combine electrochemical compression with metal hydride-based thermal compression to achieve hybrid, highly-efficient, safe and silent H2 compressors. All these objectives will be addressed through multidisciplinary approaches in materials science, engineering, device integration, modelling and social sciences.
Maha RHANDI, Florence DRUART, Jonathan DESEURE, Modelling of electrochemical hydrogen pumping: fundamental 1D approach, 8th International Conference on ”Fundamentals & Development of Fuel Cells FDFC2019
Mathieu Salaun, Pierre Gaffuri, Isabelle Gautier-Luneau, M. Bardet, Vincent Maurel, Atul Sontakke, et al.. New generation of aluminum borate phosphors for white LEDs lighting prepared by the polymeric precursor method (modified Pechini). 8th International Symposium on Optical Materials, Jun 2019, Wraslaw, Poland
Mathieu Salaun, Isabelle Gautier-Luneau, Michel Bardet, Vincent Maurel, Atul D. Sontakke, et al.. New generation of aluminum borate phosphors for white LEDs lighting prepared by the polymeric precursor method (modified Pechini). Congrès RX et matière, Nov 2019, Nancy, France
Juan Jose Cortez, A. Bidaud, Silvana Mima, Gabin Mantulet, Elena Stolyarova. Assesment of the Demand Respons Aplication in Europe and its Complementary/Competitive Character with Storage Technologies. Local energy, global markets, 42nd IAEE international conference, International Association of Energy Economics, May 2019, Montréal, Canada. ?hal-02150581?
H.H. Tran, R.B. Venkatesh, Y. Kim, D. Lee, and D. Riassetto, Multifunctional composite films with vertically aligned ZnO nanowires by leaching-enabled capillary rise infiltration. Nanoscale, 2019. 11(45): p. 22099-22107. 10.1039/C9NR07183K.
J. Resende, O. Chaix-Pluchery, M. Rovezzi, Y. Malier, H. Renevier, N.D. Nguyen, J.-L. Deschanvres, and C. Jiménez, Resilience of Cuprous Oxide under Oxidizing Thermal Treatments via Magnesium Doping. The Journal of Physical Chemistry C, 2019. 123(14): p. 8663-8670. 10.1021/acs.jpcc.9b00408.
V.H. Nguyen, J. Resende, D.T. Papanastasiou, N. Fontanals, C. Jiménez, D. Muñoz-Rojas, and D. Bellet, Low-cost fabrication of flexible transparent electrodes based on Al doped ZnO and silver nanowire nanocomposites: impact of the network density. Nanoscale, 2019. 11(25): p. 12097-12107. 10.1039/C9NR02664A.
D. Muñoz-Rojas, T. Maindron, A. Esteve, F. Piallat, J.C.S. Kools, and J.M. Decams, Speeding up the unique assets of atomic layer deposition. Materials Today Chemistry, 2019. 12: p. 96-120. 10.1016/j.mtchem.2018.11.013.
F. Morisot, V.H. Nguyen, C. Montemont, T. Maindron, D. Muñoz-Rojas, M. Mouis, M. Langlet, and C. Ternon, Al2O3, Al doped ZnO and SnO2 encapsulation of randomly oriented ZnO nanowire networks for high performance and stable electrical devices. Nanotechnology, 2019. 30(38): p. 385202. 10.1088/1361-6528/ab2aa5
L. Lecarme, V. Consonni, F. Lafolet, T. Cossuet, M. Mermoux, F. Sauvage, A. Nourdine, F. Alloin, and J.-C. Leprêtre, ZnO Nanowires as a Promotor of High Photoinduced Efficiency and Voltage Gain for Cathode Battery Recharging. ACS Applied Energy Materials, 2019. 10.1021/acsaem.9b00783.
C. Lausecker, B. Salem, X. Baillin, H. Roussel, E. Sarigiannidou, F. Bassani, E. Appert, S. Labau, and V. Consonni, Formation mechanisms of ZnO nanowires on polycrystalline Au seed layers for piezoelectric applications. Nanotechnology, 2019. 30(34): p. 345601. 10.1088/1361-6528/ab1d6e.
C. Lausecker, B. Salem, X. Baillin, and V. Consonni, Modeling the Elongation of Nanowires Grown by Chemical Bath Deposition Using a Predictive Approach. The Journal of Physical Chemistry C, 2019. 10.1021/acs.jpcc.9b08958.
P. Gaffuri, E. Appert, O. Chaix-Pluchery, L. Rapenne, M. Salaün, and V. Consonni, The Path of Gallium from Chemical Bath into ZnO Nanowires: Mechanisms of Formation and Incorporation. Inorganic Chemistry, 2019. 58(15): p. 10269-10279. 10.1021/acs.inorgchem.9b01413.
G.K. Deyu, D. Muñoz-Rojas, L. Rapenne, J.-L. Deschanvres, A. Klein, C. Jiménez, and D. Bellet, SnO2 Films Deposited by Ultrasonic Spray Pyrolysis: Influence of Al Incorporation on the Properties. Molecules, 2019. 24(15): p. 2797.
G.K. Deyu, J. Hunka, H. Roussel, J. Brötz, D. Bellet, and A. Klein, Electrical Properties of Low-Temperature Processed Sn-Doped In2O3 Thin Films: The Role of Microstructure and Oxygen Content and the Potential of Defect Modulation Doping. Materials, 2019. 12(14): p. 2232.
V. Consonni, J. Briscoe, E. Kärber, X. Li, and T. Cossuet, ZnO nanowires for solar cells: a comprehensive review. Nanotechnology, 2019. 30(36): p. 362001. 10.1088/1361-6528/ab1f2e.
A.H. Alshehri, K. Mistry, V.H. Nguyen, K.H. Ibrahim, D. Muñoz-Rojas, M. Yavuz, and K.P. Musselman, Metal-Insulator-Metal Diodes: Quantum-Tunneling Metal-Insulator-Metal Diodes Made by Rapid Atmospheric Pressure Chemical Vapor Deposition (Adv. Funct. Mater. 7/2019). Advanced Functional Materials, 2019. 29(7): p. 1970042. 10.1002/adfm.201970042.
S. Aghazadehchors, V.H. Nguyen, D. Muñoz-Rojas, C. Jiménez, L. Rapenne, N.D. Nguyen, and D. Bellet, Versatility of bilayer metal oxide coatings on silver nanowire networks for enhanced stability with minimal transparency loss. Nanoscale, 2019. 10.1039/C9NR05658K.
- production of electricity through innovative solar cells
- saving of energy by using highly efficient lighting devices made of innovative LEDs
- storage of energy from hydrogen (as briefly illustrated below)
Publications
C. Verrier, E. Appert, O. Chaix-Pluchery, L. Rapenne, Q. Rafhay, A. Kaminski-Cachopo, V. Consonni, “Effects of the pH on the Formation and Doping Mechanisms of ZnO Nanowires Using Alimunium Nitrate and Ammonia”, Inorganic Chemistry 66 (2017), 13111-13122.
D. Muñoz-Rojas, V.H. Nguyen, C. Masse de la Huerta, S. Aghazadehchors, C. Jiménez, D. Bellet, “Spatial Atomic Layer Deposition (SALD), an emerging tool for energy materials. Application to new generation photovoltaics and transparent conductive materials”, Comptes Rendus de l’Académie des Sciences 18 (2017) 391-400
Romain Parize, Jérôme Daniel Garnier, Estelle Appert, Odette Chaix-Pluchery, and Vincent Consonni, Effects of Polyethylenimine and Its Molecular Weight on the Chemical Bath Deposition of ZnO Nanowires, ACS Omega 2018 3 (10), 12457-12464. DOI: 10.1021/acsomega.8b01641
Thomas Sannicolo, Nicolas Charvin, Lionel Flandin, Silas Kraus, Dorina T. Papanastasiou, Caroline Celle, Jean-Pierre Simonato, David Muñoz-Rojas, Carmen Jiménez, and Daniel Bellet. Electrical Mapping of Silver Nanowire Networks: A Versatile Tool for Imaging Network Homogeneity and Degradation Dynamics during Failure. ACS Nano 2018 12 (5), 4648-4659. DOI: 10.1021/acsnano.8b01242
Nguyen, Gottlieb, Valla, Muñoz, Bellet, Muñoz-Rojas. Electron tunneling through grain boundaries in transparent conductive oxides and implications for electrical conductivity: the case of ZnO:Al thin films. Materials Horizons, 5 (2018) 715-726 . DOI: 10.1039/C8MH00402A
D. Damianos, G. Vitrant, A. Kaminski-Cachopo, D. Blanc-Pelissier, G. Ghibaudo, M. Lei, J. Changala, A. Bouchard, X. Mescot, M. Gri, S. Cristoloveanu, I. Ionica. Hazy Al2O3-FTO Nanocomposites: a Comparative Study with FTO-based Nanocomposites Integrating ZnO and S:TiO2 Nanostructures. Nanomaterials, 8 (2018) 440
Nguyen, Bellet, Masenelli, Muñoz-Rojas. "Increasing the Electron Mobility of ZnO-Based Transparent Conductive Films Deposited by Open-Air Methods for Enhanced Sensing Performance". ACS Applied Nano Materials 1, 12 (2018) 6922–6931
V. Maryasin, Q. Rafhay, D. Bucci, J. Michallon, and A. Kaminski-Cachopo. Opto-electrical simulation of III-V nanowire based tandem solar cells on Si. AIP Conference Proceedings 1999, 120001 (2018)
Norton, Farrell, Mullarkey, Caffrey, Oser, Bellet, Shvets, Fleische, Bending stability of CuxCrO2- a transparent p-type conducting oxide for large area flexible electronics, AIP Advances, 8 (2018) 85013
P. Gaffuri, E. Appert, C. Verrier, O. Chaix-Pluchery, L. Rapenne, E. Sarigiannidou, Q. Rafhay, A. Kaminski-Cachopo, A. Ibanez, M. Salaün, V. Consonni, Development of the Doping of ZnO Nanowires Using Metal (III) Elements in Aqueous Solution, Journées de la Matière Condensée, Grenoble, aout 2018
P. Gaffuri, E. Appert, C. Verrier, O. Chaix-Pluchery, L. Rapenne, Q. Rafhay, A. Kaminski-Cachopo, A. Ibanez, M. Salaün, V. Consonni, Monitoring the morphology and doping of ZnO nanowires by chemical bath deposition using metal nitrate, EMRS Fall Meeting, Varsovie, sept 2018
P. Gaffuri, E. Appert, C. Verrier, O. Chaix-Pluchery, L. Rapenne, Q. Rafhay, A. Kaminski-Cachopo, A. Ibanez, M. Salaün, V. Consonni, N-type doping of ZnO nanowires grown by chemical bath deposition using metal nitrate and ammonia., EMRS Spring Meeting, Strasbourg, mai 2018
P. Gaffuri, M. Salaün, I. Gautier-Luneau, E. Appert, V. Consonni, A. Ibanez, New generation of lanthanides-free phosphors for white LEDs lighting prepared by the polymeric precursor method, Journées de la Matière Condensée, Grenoble, aout 2018
Resende, Sannicolo, Khan, Charvin, Nourdine, Papanastasiou, Nguyen, Aghazadehchors, D. Muñoz-Rojas, Jiménez, Nguyen, Flandin, Bellet, Optimizing the properties of transparent electrodes based on silver nanowire networks for integration into organic solar cells, Material Research Society, Boston, Novembre 2018
Bellet, Properties, challenges and limits of metallic nanowire networks: a brief overview, Material Research Society, Boston, Novembre 2018
Bellet, Transparent electrodes for multifunctional windows: a brief overview, Material Research Society, Boston, Novembre 2018
Langley, Lagrange, Nguyen, Bellet. Percolation in networks of 1-Dimensional objects: Comparison between Monte Carlo simulations and experimental observations. Nanoscale Horizons, 3 (2018) 545-550
Masse de la Huerta, C.; Nguyen, V.H.; Dedulle, J.-M.; Bellet, D.; Jiménez, C.; Muñoz-Rojas, D. Influence of the Geometric Parameters on the Deposition Mode in Spatial Atomic Layer Deposition: A Novel Approach to Area-Selective Deposition. Coatings 2019, 9, 5.
Afzal Khan, Viet Huong Nguyen, David Muñoz-Rojas, Sara Aghazadehchors, Carmen Jiménez, Ngoc Duy Nguyen, and Daniel Bellet. Stability Enhancement of Silver Nanowire Networks with Conformal ZnO Coatings Deposited by Atmospheric Pressure Spatial Atomic Layer Deposition. ACS Applied Materials & Interfaces 2018 10 (22), 19208-19217. DOI: 10.1021/acsami.8b03079
Randhi, Tregaro, Deseure, Druart, Chatenet. Pros and Cons of electrochemical hydrogen compression - a review/perspective. Chinese Journal of Catalysis (2019)
V. Consonni, J. Briscoe, E. Kärber, X. Li, T. Cossuet. ZnO Nanowires for Solar Cells: A Comprehensive Review. Nanotechnology (2019)
AUBRAS, RHANDI, DESEURE, KADJO, Bessafi, GRONDIN-PEREZ, DRUART, Chabriat. Modeling of pressurized PEM water electrolysis using dimensionless approach. International journal of hydrogen energy. 2019
Marine Trégaro, Frédéric Maillard, Christophe Geantet, Marian Chatenet , Anode electrocatalysts for the electrochemical purification and compression of hydrogen, Fundamental and Devevopment of Fuel Cells, FDFC 2019, Nantes
Published on March 17, 2020
- Research Fronts
- Design of interactive systems to involve occupants of connected buildings
- Emerging behaviors, from individual to communities
- Interactions modeling between buildings and with grids in a district
- Architectures for integration of renewable on-the-spot generation (ROG)
- Components and materials: specifications for a proper integration into systems
